Separate URLS for dircet SSO auto-redirect vs. manual username/password login for domain accounts?
we are currently configuring SSO for our Dynatrace Managed environment and would like to know if it is possible to offer tow different login URLS for regular domain users:
1. Auto-redirect SSO-URL: A direct URL that immendiately redirects the user to our SSO Identity Provider without any manual interaction.
2. Manual Login URL: A separate URL where users can manually enter their standard domain credentials - for example, when logging in form a non-domain machine.
Hey, this is possible during setup. You’ll have the option to choose the login page—selecting Standard + SSO will do what you’re looking for.
One other piece of advice: if you select SSO only and something goes wrong with the SSO configuration, there is a hidden URL path you can use:
/admin/login
This will always take you to the Dynatrace login screen for an admin user and bypass the SSO configuration. (allowing you to fix possible issues)
