I have a key service (its a payment service) so I want to know when we are not receiving requests or when the service has low load, so I decided to enable the “detect service load drops” with the follow configuration:
As soon as you toggle that switch to detect service load drops, the Dynatrace AI starts to learn the typical load of the service over a one-week period. Service outage detection is activated once the one-week learning period has passed. You should be receiving alerts/seeing problems showing up under the Problems tab after the learning period passed. Automated multi-dimensional baselining — Dynatrace Docs
This can also happen if the Service has quite low load in general or the traffic pattern fluctuates a lot.
As Moe mentioned, these alerts work based on the 7-day baseline for that service. From observing traffic over the 7-day period, the Dynatrace AI will form a corridor of accepted values based on which it makes predictions and decides whether the observed traffic is expected or unexpected. If the corridor is wide enough, it may happen that 0 requests/min. is low load, but not unexpected low load, therefore not resulting in an alert.
If your Service often hovers at 1-2 requests/min. or normally has periods with 0 requests/min., then a custom alert for request count at 0 requests/min. might be more appropriate than using the “traffic drop” alerts.
