Service specific monitoring dashboards using Management Zones
Management Zones is very useful feature and we are able to segregate
the dashboards based on app environments.
However, if I want to build any app. specific dashboards (Example
: Services dashboard, we created the
management zone for each app/service and trying to use the Services dashboard
based on service name), the management zones are not allowing to customize the tile/chart
based on the selected service name. It is just reusing the same service performance
chart across all the management zones.
Please advise if there is any solution to build service
specific dashboard in each management zone. Can we customize/filter the chart criteria
based on the management zone ?
you need to ensure that your management zone is also defined for services. When we create Management Zones we ensure we apply it to hosts, process groups, and services, along with checking the box to trickle this down on all the applicable entities. Only then will you be able to see the services
