ServiceNow notifications: Problem link is broken in the ServiceNow incident
  1. Check if you’ve turned on the Use text format for problem details instead of HTML toggle in your Dynatrace notification configuration.
  2. If problem details are to be sent in plain text format, you also need to also change the Problem Details field in the ServiceNow Problems import set table from the default type HTML to text. The image below shows the Problem Details field in HTML, which needs to be changed to text.
  3. Find the table x_dynat_ruxit_problems and change the type of the problem details field x_dynat_ruxit_problems.details from HTML to type string.
