What is session timeout duration if user logs into DT managed and does nothing. Also can we modify it?
It’s by default 60 minutes. User will be logged out after the timeout if page is not auto-refreshed. Otherwise, each refresh will reset the timeout. For most of the pages there should be no auto-refresh, though. You can adjust the timeout by updating config.properties or providing a custom.settings file.
We are working now on exposing that configuration to REST API and Web UI. That should be available early 2020.
