Set location for IP range of local network
Dear All,
Do we have a way to create to map IP addresses for the local network as we have in the AppMon OOB?
Babar
Yes there is no problems with such mappings. Go to Settings => Web & mobile monitoring => Map IP addresses to locations.
You can download there sample CSV file and then import it with data or you can put it manually.
Hello @sebastian k.
Thank you for sharing a desired information.
I could not find the sample CSV file? Can you share the exact location or file with me?
Are geographic coordinates mandatory in the CSV file?
Babar
You have to click more on this page and you will see :slightly_smiling_face:
Is there a way to import IP mappings via the API? I’d like to automate a periodic update process with our network team.
