Share Edit permissions with other users for classic dashboards
According to this documentation - Share Dynatrace dashboards — Dynatrace Docs I should be able to provide Edit permissions to other users for my classic dashboards, but this options are not presented in my Dashboard Sharing settings. I only see this -
Is it a problem with my user’s permissions or this functionality is not there ?
Thanks a lot.
Answer my own question - in order to get permissions options, one needs to uncheck Preset checkbox:
I think you should turn off “Public as present” in advance.
Best regards
Yep, figured it out - not really intuitive
