Hi all,
I have a simple question, but it seems to be complicated at the same time
I am simply looking to show the status UP or down for my process or process group but not baised on availability %
a simple tile, not a pourcentage
Regards
Hi all,
Regards
Question for clarification here on this - what exactly do you mean by up or down? There are a couple of visualizations that are available OOB from the classic dashboards. If you can describe what visualization you’re looking for, we could look for a solution from there.
In terms of if a status is UP or DOWN, that could also depend on what you categorize as up or down for your specific environment (percentage of availability that classifies it as such).
For now, linking this here to look into:
