@Martin K. I would suggest you use a Auto tag and select to have the tags be applied not only at the host level, but the process and service level. Also check the permission level of the management zone within the CMC/SaaS admin page. I’d check the rights first to ensure that everything is set correctly
When you go to application list, you swe there your application When Management zone filter is active? Are you sure that this application jadę user sędziom properly recorded? Did you tried pick up different timeframe?
lol, this is very common type of mistake in dt gui, last time i was creting api detection rule 3 times until i found save button. in some sections there are multiple save buttons on upper and also on lower part of screen.
