I’m experiencing an issue deploying the EasyTravel environment via Docker on an EC2 instance (Amazon Linux).
All services start correctly with docker compose up, and the containers (frontend on ports :80, :8080, and :9079) are accessible. Data is successfully reported to Dynatrace.
However, the loadgen container consistently fails to start with the following error:
Exception in thread “main” java.lang.NoClassDefFoundError: com/fasterxml/jackson/databind/ObjectMapperat ch.qos.logback.contrib.jackson.JacksonJsonFormatter.<init>(Unknown Source)…Caused by: java.lang.ClassNotFoundException: com.fasterxml.jackson.databind.ObjectMapper
This is blocking me because it doesn’t generate problems. What modification can be made to correct this and simulate problems?
