Hi community,
I would like to use Davis AI analysis capacities with SINGLE VALUE visualization.
The purpose is get dynamic thresholds, based on Davis calculated baselines, in order to change Single value background color tile.
Do you know if it is feasible?
Thank you
Regards
Freddy
As far as I can tell, the DavisAI analysis results are only usable if the “Davis AI analysis” visualization type is selected. I don’t believe there is currently a way to incorporate the baseline data into your own DQL query for use with other visualizations. Perhaps worth submitting a product idea.
Thank you for your answer Marco.
I have come to thé same conclusion
Best regards
Freddy
