I have a list of devices that end with the oid :
Es.
2606.7.4.1.2.1.3.1 = Device12606.7.4.1.2.1.3.2 = Device22606.7.4.1.2.1.3.3 = Device3
the last number of oid is the index of the device. (colored red)
I need the corresponding value, but on other table doesn’t end with the same index
Es.
2606.7.4.2.2.1.4.1.2 = INTEGER: 10
2606.7.4.2.2.1.4.2.2 = INTEGER: 20
2606.7.4.2.2.1.4.3.2 = INTEGER: 30
Is possible to custom the oid with a regex or someting like that ?
dimensions:
- key: custom.snmp.test.device
value: oid:2606.7.4.1.2.1.3
metrics:
- key: custom.snmp.test.value
value: oid:2606.7.4.2.2.1.4.{custom.snmp.test.device}.2
I hope I have explained myselfI appreciate any advice, I’ve been struggling with it for daysThank you
