SNow Integration Events?
I was looking for more information about the Events associated with the Workflow Integration for ServiceNow, I also found events like the one below. Is there any documentation about them?
      "timestamp": "2026-04-13T04:11:33.076000000+01:00",
      "dt.event.correlation_id": "a0c75b6614afde2c502da385233dccc9",
      "servicenow.number": "CTASK0010005",
      "servicenow.sys_id": "f2c0a34e87a2fa145f6aca6e0ebb35c3",
      "servicenow.url": "https://ven07742.service-now.com/change_task.do?sys_id=f2c0a34e87a2fa145f6aca6e0ebb35c3",
      "servicenow.short_description": "image provider lambda function update",
      "event.category": "INFO",
      "dt.davis.is_frequent_issue_detection_allowed": false,
      "servicenow.state": "2",
      "dt.davis.mute.status": "NOT_MUTED",
      "dt.source_entity.type": "service",
      "event.end": "2026-04-13T04:26:33.075000000+01:00",
      "affected_entity_types": [
        "dt.entity.service"
      "event.group_label": "Custom info",
      "event.status": "CLOSED",
      "dt.source_entity": "SERVICE-42411741F5F4AC50",
      "dt.entity.service.name": "image-provider-live in us-east-1",
      "dt.davis.impact_level": "Services",
      "dt.smartscape_source.type": "SERVICE",
      "dt.smartscape.service": "SERVICE-42411741F5F4AC50",
      "servicenow.description": "image provider lambda function update",
      "dt.entity.service": "SERVICE-42411741F5F4AC50",
      "servicenow.record_type": "Change Task",
      "event.kind": "DAVIS_EVENT",
      "affected_entity_ids": [
      "dt.smartscape_source.id": "SERVICE-42411741F5F4AC50",
      "event.severity": "5",
      "smartscape.affected_entity.ids": [
      "servicenow.link": "[CTASK0010005](https://ven07742.service-now.com/change_task.do?sys_id=f2c0a34e87a2fa145f6aca6e0ebb35c3)",
      "event.name": "ServiceNow Change: CTASK0010005",
      "dt.davis.is_frequent_event": false,
      "event.provider": "EVENTS_REST_API_INGEST",
      "dt.security_context": [
        "null"
      "dt.davis.timeout": "15",
      "servicenow.ctask_type": "implementation",
      "maintenance.is_under_maintenance": false,
      "event.description": "ServiceNow Change: CTASK0010005",
      "event.type": "CUSTOM_INFO",
      "event.status_transition": "CREATED",
      "smartscape.affected_entity.types": [
        "SERVICE"
      "event.id": "-3198009319573973808_1776049893075",
      "event.start": "2026-04-13T04:11:33.075000000+01:00",
      "servicenow.record_table": "change_task",
      "dt.openpipeline.source": "classic_rest_api",
      "dt.openpipeline.pipelines": [
        "davis.events:pipeline_Ownership_for_OpenTelemetry_Demo"
