When I try the same on other env it works correct. Can someone with access check what happens and what we can do if something like this happens on our customer env?
@deni everything is fine.
The (classic) Logs & events app was designed for querying logs, thus, you don’t have any common fields for spans selected and fields like “content” are typically empty. Use Notebooks for querying spans (preferred) or select the fields.
If anything is broken, open a support ticket or chat, but I recommend always double-check things first before raising one.
