Sort by ascending Code Calculated Metric - Data explorer
created free connection pool percentage on WebLogic process metrics. Cannot sort by highest percentage value. Trying to check if someone found way to resolve issue.
Metrics used for calculation
builtin:tech.weblogic.connectionPool.ActiveConnectionsCurrentCount
builtin:tech.weblogic.connectionPool.MaxCapacity
When using the data explorer you should see a “+” symbol in the UI which allows you to add the “Sort by” functionality seen here:
Once that is selected you will be able to choose Ascending or descending. I would also suggest using the “last value” selection if you are trying to see the current value being reported.
If you are trying to use the code tab then you can see under the “Sort” section there is the possibility to add “ascending” or “descending”. Seen here in the metric selector documentation:
builtin:tech.weblogic.connectionPool.ActiveConnectionsCurrentCount:splitBy(“dt.entity.process_group_instance”):avg:auto:sort(value(avg,descending))
Hope this helps.
-Dallas
added last part to calculation and it worked. Thanks
:sort(value(avg,descending))*100
Hello mcabiya,
could you share how did u make the metric calculation?
Thank you in advance.
Best Regards,
David
I used tag to filter process. Try adding tag or removing filter from metric.
(builtin:tech.jvm.memory.pool.used:filter(and(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“TAG~”)”)))):splitBy(“dt.entity.process_group_instance”))/(builtin:tech.jvm.memory.pool.max:filter(and(in(“dt.entity.process_group_instance”,entitySelector(“type(process_group_instance),tag(~“TAG~”)”)))):splitBy(“dt.entity.process_group_instance”)):sort(value(avg,descending))*100
