Summary
This troubleshooting article should help you resolve the most common issues for SQL extensions
Failed to assign monitoring configuration
Problem
As SQL extension fast checks only attempt to verify connectivity to the configured database, this issue will typically be related to either network issues/timeouts or authorization issues with the account that was configured in the monitoring configuration.
Solution
The resolution of this issue will be dependent on the error returned by the fast-check, however, double-checking the hostname, username and password are all valid is a good place to start. You can see below how to resolve different connection issues.
Unable to connect to database
Problem
There’s a whole host of reasons why the extension might be unable to connect to the database. Below is a list of the most common ones and ways to investigate them.
In all cases, review the datasource logs on your ActiveGate server and look for connection exceptions.
Connection information issues
Double check that your host, port, database name and username, and password are correct.
Network issues
Troubleshooting steps:
- If you are using a custom extension verify that the JDBC driver and that you’re trying to connect to a supported DB version.
- Use tools like Netcat or Telnetto on the ActiveGate server to verify host availability.
- Host unreachable – there’s some underlying network issue that needs to be resolved by your server/network administrator
- Host reachable – go to the next step.
- Use the Dynatrace connection tool to verify connection to the database.
- Connected successfully – please reach out to support and supply information about all the steps that you have taken to verify the connection.
- Connection problem – go to step 4
- Provide an external tool to verify the connection to the database (our recommendations in TOOLS section)
- Connection problem – your ActiveGate server is unable to connect to the database which means that there’s some underlying server or network issue which will need to be resolved by your administrator.
Connection issues can manifest in a multitude of ways, specific to each database vendor. Look for error codes in the connection for exception messages and see driver documentation for the particular error (linked below).
SSL certificate issues
- Verify
- Truststore name: sqlds_truststore
- Truststore password: sqlds_truststore
- Truststore default path:
- Windows: %PROGRAMDATA%\dynatrace\remotepluginmodule\agent\conf\userdata
- Unix: /var/lib/dynatrace/remotepluginmodule/agent/conf/userdata
- No other truststore is in its directory
- Truststore and its directory permissions (too many permissions my also cause problems!)
- CN in the certificate matches the hostname in the connection string.
- If you have more than one certificate in the truststore, create a new one with a single certificate. (Remember to move the other truststore to a different directory)
Metric data is missing
Problem
This is a common issue with SQL-based extensions. There are two main reasons why this will occur:
- A feature set responsible for generating the metric is not turned on
- The query responsible for the metric did not generate any results
Checking selected feature sets
Look at your extension configuration and review the list of selected feature sets.
Query does not return results
If this happens you will see an “Empty result for query” message in the datasource logs, along with the query itself. Copy the query that returned an empty result from the extension.yaml file and run it manually as the user in the monitoring configuration to determine if the query still returns an empty result.(link to article: Query Behind a Metric)
If the query returns no results it is likely that permissions to the proper table(s) are not granted to the configured extension user or it can occur if a customer has left feature sets enabled for features that they don’t have implemented, such as always-on SQL servers in MS SQL, if the SQL server is not configured for high availability then the query for that data will be empty.
List of permissions required by various DB vendors listed in Extension details in the Hub:
Irregular data issues
Keywords: restart, crash, resource consumption
Problem
Sometimes it happens that the extension correctly connects to the database and starts collecting data that can be seen in the UI on dashboards or in Data Explorer, but there are holes or unexpected gaps in the data.
The most common reason for this situation is restarting Extension Framework components, i.e.: the Java-DataSource, Extension Execution Controller or Active Gate. To confirm this, check the logs of these components. You can find the reason for the restart in the logs, most often they are:
- update
- exceeding the permissible load limits of the machine, see: About Extensions — Dynatrace Docs
- unexpected crash.
An alternative to viewing logs may be the analysis of Self-Monitoring metrics for:
- Datasource - SQL
- Extension - Engine
- Active Gate: see: ActiveGate self-monitoring metrics — Dynatrace Docs
Troubleshooting
- Verify the Java-DataSource, EEC and ActiveGate logs:
- Look for restarts (CTRL + F => “starting“ should find it)
- analyze what happened before restart
- analyze how often a restart occurs
- Verify Self-Monitoring metrics
Useful Information
Error codes
Database documentation to read about error codes:
Default platform paths
(used in further descriptions, could be customized!):
Windows
- EEC installation directory → C:/Program Files/dynatrace/remotepluginmodule/ EEC operation directory → C:/ProgramData/dynatrace/remotepluginmodule
Linux
- EEC installation directory → /opt/dynatrace/remotepluginmodule/
- EEC operation directory → /var/lib/dynatrace/remotepluginmodule/
Datasource
- <DATASOURCE_EXECUTABLE_NAME>.log (<EEC operation directory>\log\extensions\datasources\) - log files of the datasource, named after DS executable, e.g dynatracesourcesql.log or dynatracesourcesnmp.log
EEC
- extensions.conf (<EEC installation directory>agent\conf) - AG address for communication, tenant number and log level (is replaced by template on each update)
- extensionsuser.conf (<EEC installation directory>\agent\conf)
- ruxitagent.conf (<EEC installation directory>\agent\conf) - The base URL of the Collector/Server this agent should connect to
- ruxitagent_extensionsmodule_<PID>.log (<EEC operation directory>\log\extensions) - logs started DS jobs / tasks - you can check there if EEC had problem starting some job. EEC logs are in the
- ruxitagent_extensionsmodule_xxxxx.log files.
Tools
- Connection Tool → our internal tool used for connection verification
- External JDBC connection tool: DBWeaver
- External pinging and connecting tools: Telnet. Netcat
What’s next
If none of the solutions above has worked for you and you are still experiencing issues with the SQL extension you are trying to configure there’s always a chance that there is a problem with the extension itself or the underlying data source.
In that case feel free to open a support ticket specifying:
- A description of the problem, ideally, with screenshots
- What extension you are trying to configure and its version
- If it’s a custom extension please provide the extension YAML or ZIP file
- Dynatrace version
- ActiveGate version
- Extensions Module version
- A list of troubleshooting steps that have been performedhttps://community.dynatrace.com/t5/Troubleshooting/
