How do I set up the alarm if I need to have a warning baseline of SQL query that is greater than 10ms?
Just like in the picture, how do I set the value to achieve my goal?
There has been updates to the anonloy detections of Databases. You should now see the following settings:
This will allow you to fine grain your alerts
