SSO Error When Using run Start
I am currently able to create an app using the following versions.
Node JS Windows : V20.11.0
dt-app@0.115.5
Microsoft Windows [Version 10.0.19045.4291]
(c) Microsoft Corporation. All rights reserved.
C:\Users\XXXXXX>node --version
v20.11.0
C:\Users\XXXXXX>npx dt-app@0.115.5 create
Hello there! Welcome to the Dynatrace App Toolkit.
You can build, develop, and deploy your apps all from here.
Now we'll just need a few details to get you going!
? Enter the name for your app
C:\Users\XXXXXX>cd documents
C:\Users\XXXXXX\Documents>npx dt-app@0.115.5 create
? Enter the name for your app DynApp
? Enter your environment url https://{environmentid}.apps.dynatrace.com
√ Successfully installed all dependencies
Git not found, skipping repository creation
Your setup is complete, you can start hacking!
After the app is created, When I try to run the dev server using npm run start, I am encountering the following issue.
I am connected to my office network using VPN and trying to run the following command.
C:\Users\XXXXXX\Documents>cd dyn-app
C:\Users\XXXXXX\Documents\dyn-app>npm run start
> dyn-app@0.0.0 start
> dt-app dev
 DT-APP:  Started local development server
Error: Could not resolve the SSO-URL for 'https://{environmentid}.apps.dynatrace.com'
Http(s) request failed: read ECONNRESET
Terminate batch job (Y/N)? y
C:\Users\XXXXXX\Documents\dyn-app>code .
Error: Could not resolve the SSO-URL for ‘https://{environmentid}.apps.dynatrace.com’
When I look at the following path for log file,
C:\Users\XXXXXXXX\Documents\dyn-app\.dt-app\logs
I see the following :
2024-04-24T17:40:56.144Z DEBUG [TELEMETRY] Reading package.json
2024-04-24T17:40:56.160Z DEBUG [TELEMETRY] Initializing OpenKit
2024-04-24T17:40:59.552Z DEBUG [TELEMETRY] Creating a new HTTP and HTTPS://{environmentid}.apps.dynatrace.com'
2024-04-24T17:41:07.541Z DEBUG [HTTP(S)] Execute GET request without allowing redirection to 'https://{environmentid}.apps.dynatrace.com/platform/oauth2/authorization/dynatrace-sso'
2024-04-24T17:41:07.542Z DEBUG [TELEMETRY] Tracing request https://{environmentid}.apps.dynatrace.com/platform/oauth2/authorization/dynatrace-sso
2024-04-24T17:41:07.748Z DEBUG [AUTH] Could not resolve the SSO-URL for 'https://{environmentid}.apps.dynatrace.com'
2024-04-24T17:41:07.748Z DEBUG [AUTH] Error: Http(s) request failed: read ECONNRESET
2024-04-24T17:41:07.750Z ERROR Error: Could not resolve the SSO-URL for 'https://{environmentid}.apps.dynatrace.com'
2024-04-24T17:41:07.750Z DEBUG [TELEMETRY] Reporting crash
2024-04-24T17:41:07.750Z DEBUG [TELEMETRY] Closing OpenKit connection
Can you please let me know what am i missing?
If Any proxy settings are required, Please let me know where do I need to execute.
UPDATE : The app ran successfully when VPN was disabled. Can you please let me know where can i find instructions for setting up Proxy in case of VPN.
Thanks in advance.
Hi @DD_Developer,
Have you looked at the proxy server section of our connectivity issues troubleshooting guide? You need a proxy server (for HTTP and HTTPS connections) configured on your machine, as well as set it up according to your company settings.
Kind regards,
Sarah
@SarahFaustmann ,
Thanks for the documentation about proxy settings. I did notice that we have a proxy server by using the following command
echo %http_proxy%
How do I configure this at the machine level? Do I need to execute the following commands ?
export HTTP_PROXY=<your proxy>
export HTTPS_PROXY=<your proxy>
Hi @DD_Developer, the command for configuring proxies in Windows is a bit different. This should work:
set HTTP_PROXY=http://proxy_userid:proxy_password@proxy_ip:proxy_port
set HTTPS_PROXY=http://proxy_userid:proxy_password@proxy_ip:proxy_port
Let us know if we can help in any other way.
Hi @DD_Developer,
Did @educampver’s comment help you? If so, would you be so kind as to accept this as solved? Thank you! 🙂
Best,
Sarah
Hi educampver,
Thank you for the good videos about AppFunctions, they were informative and encourged me to use AppFunction in my projects, I seems to be having the same constant issue, I was able to deploy before but it did stop working and I am now stuck not sure what happens - is not working for me anymore (see SSO error below)
PS C:\Users\U\DEV\Dynatrace\cm-api> npx dt-app dev
Starting development server…
Port 3000 is already in use. Using port 3001 instead.
Warning ──────────────────────────────────────────────────────────────────────────────────
Failed to retrieve user details. App functions will use placeholder data.
Error: SSO-URL for ‘https://{environmentid}.apps.dynatrace.com’ could not be processed.
fetch failed
If you need further assistance visit the connectivity troubleshooting guide here: dt-url.net/c4jp0s12" target=“_blank”>https://dt-url.net/c4jp0s12
In the deploy part I get a couple message that my extension is not authorised - so I accept the notfifications twice but this does not help and the above error always occurs
Also in my Visual Code, I see a brown that DT is not Authirised how can this be resolved
I appreciate any feedback to resolve my deployment issues
I seem to have a work around and it only works if I do it outside visual studio, not sure what needs to be done to start the development server or the deploy inside Visual Studio, if anyone knows, I will be interested.
But here is my contribution to the community for now; I can deploy to my instance:
set NODE_TLS_REJECT_UNAUTHORIZED=0
C:\Users\U\DEV\Dynatrace\cm-api>npx dt-app dev
(node:20176) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to ‘0’ makes TLS connections and HTTPS requests insecure by disabling certificate verification.
(Use `node --trace-warnings …` to show where the warning was created)
Authenticated as MY_USER
C:\Users\1026014>set NODE_TLS_REJECT_UNAUTHORIZED=0
C:\Users\U\DEV\Dynatrace>cd cm-api
C:\Users\U\DEV\Dynatrace\cm-api>npx dt-app deploy
Deploying app…
(node:21984) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to ‘0’ makes TLS connections and HTTPS requests insecure by disabling certificate verification.
√ Creating bundles…
√ Built the app
√ Compressed app artifact
Hope this helps.
√ App is deployed
Done.
