Standard Dashboard for Synthetic Monitoring browser and HTTP monitoring
Please share if  you have the standard dashboard for synthetic monitoring browser and http monitoring.
I tried using the dashboard available in dynatrace playground for synthetic monitoring.
The json file was non compatible.
What are the metrics associated with the synthetic monitoring.
I would check in this tenant, not sure if it is same than “dynatrace playground”.
Best regards
it isn’t.  playground is this: Dynatrace
New dashboards or classic dashboards?
Hi Kenny
Thanks for your reply.
It is for the new dashboards
Hi Anton
I don’t have access to this page
I am not seeing anything in tenants above.  Try using classic dashboard and converting to new dashboard.  I tried this but wasn’t perfect so it would still need some work
Classic dashboard: Synthetic Monitoring.
@Arunkumarbnp Take a look at the below for the Synthetic monitoring metrics on Grail , you should be able to setup these on new dashboards
There are a couple of default dashboards that are available by default on tenants for Synthetic , take a look at them for a start.
Hi @p_devulapalli
Thanks for your reply. But am unable to add these dashboards to my dynatrace.
It says invalid json file.
@Kenny_Gillette I switched to classic dashboard and uploaded the synthetic monitoring dashboard json file
but it says incorrect json file
@Arunkumarbnp are you importing it to Gen3 or classic dashboards? These are Gen3 (new)dashboards
Open classic dashboard then you have to click menu and upgrade
Hope this makes sense
Hi @Kenny_Gillette
I don’t see an option upgrade on the options shared above
@p_devulapalli , am looking for dashboard classic.
sorry for the confusion.
Is it possible to change the json file of gen3 dashboard compatible to dashboard classic?
Are you admin in your tenant?  Are you on SaaS or Managed?
Are you admin of dashboard?
@Kenny_Gillette no, am not the admin,
am a user in dynatrace.
I believe that is why.  I have attached it from my tenant.  I didn’t make any changes
Synthetic Monitoring.json (18.9 KB)
@Kenny_Gillette Thanks for the json file for the dashboard classic
but it didn’t work
Json I added was to be inputted into new dashboards.  Not classic dashboards.
You should already have a classic dashboard named Synthetic Monitoring.
@Kenny_Gillette
I need json file of dashboard classic.
can you please share it to me?
