It’s been a while since we announced in a newsletter our plans to give the “Getting started” sub-forum a full, complex makeover. The goal was to turn it into a welcoming space for all Dynatrace beginners and give it a clear purpose, and today’s the day when we finally want to present you with the result of our hard work.
Lo and behold, brand-new, shinier than ever, “Start with Dynatrace”!
As you can see the name change was not the only transformation this space went through
The main “attraction” being, of course, our new widget:
We tried to gather the most essential materials and group them in a sensible way. Finally, the learning journey got divided into three parts: Get to know Dynatrace, Start learning, and Explore further, with every step getting you a little bit closer to the final destination - getting your Dynatrace certification 🎓
And in case you have any questions or doubts left about the learning path, there’s a Q&A section below the widget:
Thank you for your attention! And let the roads ahead of you be smooth and straight 🛣
