I was wondering how others tackle the need of configuring e.g. workflows with monaco, where in some steps a credential needs to be loaded from the vault. And that accross multiple environments.
Example:
I create a workflow which uses at some point a credential from the vault. This is deployed via monaco, just fine. The credential ID is hardcoded and then used in the workflow:
"http_create_alerts": {
"name": "http_create_alerts",
"method": "POST",
"headers": {
"Content-Type": "application/json"
"payload": "...",
"credential": {
"type": "token",
"tokenPrefix": "ApiToken",
"credentialId": "CREDENTIAL-VAULT-12132323"
Now if i push this to another environment, where the credential (with same name) exists in the vault, this obviously won’t work (the ID differs).In the workflow definition I’d rather specify the credential NAME to fetch the right one, or even better manage the credential via monaco so that it can properly reference it’s ID?
Does anyone have a strategy for that, maybe?
