Summing up columns in DataTable
Hi!
I want to sum up up every number in column in DataTable and show it under. Can anyone help resolve this issue :slightly_smiling_face: ?
You may be able to get the start of an answer with the following topic:
https://community.dynatrace.com/t5/Developer-Q-A-Forum/DataTable-subRows-documentation-missing/td-p/230076
Hi @Pawel_Zalewski,
I’ll look into this and come back to you with an attempt at a solution tomorrow.
Hi @Pawel_Zalewski,
There is currently no feature in DataTable that supports a table footer. There is the option of manually adding a row to the data and you can find this hacked solution on CodeSanbox here. Please be aware of its limitations and possible issues, though.
Best,
Sarah
Sure, thank you very much :slightly_smiling_face:
