Synthetic Availability
Is there any API call to get the latest availability of a particular synthetic ?
Hey Pranav1,
You’re in luck! There is an API call you can make for that and its documented here.
And you can also use the metrics available for it, then query with Metrics API - GET metric data point
I use these extensively. Works flawlessly.
