Hello
I have a costumer that needs to use Mobile Synthetic Monitoring, how can we do this with Dynatrace Synthetic? Somebody has an example.
Hello
If the customer is looking to synthetically test their site via a mobile device, this can be done via the synthetic monitor settings where a device profile can be set, screen orientation as well as bandwidth.
If you’re just testing the mobile version of a web browser application Chad’s answer will work. If you want to test a native mobile application (e.g. iOS, Android) you can look at using HTTP monitors and testing the API backends that the mobile apps make use of.
Multi-step HTTP monitors can help you to test workflows (e.g. get token, hit a service, etc…).
