Tag Container Group Instance by Namespace
Is it possible we can tag CGI by kubernetes namespace?
Tried it with something like
type(CONTAINER_GROUP_INSTANCE),fromRelationship.isCgiOfNamespace(type("CLOUD_APPLICATION_NAMESPACE"))
and it’s variation but no luck
Hello.
Entities matching:
type(CONTAINER_GROUP_INSTANCE),fromRelationships.isCgiOfNamespace(type(CLOUD_APPLICATION_NAMESPACE),entityName(“zoo-app”))
Result in UI:
Classic full-stack - Dynatrace Operator - Kubernetes.
Alex Romanenkov
hmm, couldn’t find it even when reduced to
type(CONTAINER_GROUP_INSTANCE),fromRelationships.isCgiOfNamespace(type(CLOUD_APPLICATION_NAMESPACE))
Hey @Ardhi, did you manage to find the solution to your problem? If so, it would be amazing if you’ve shared it with the rest of the Community! If not, let me know, and I’ll look for some further assistance 😊
Has anyone found a way to do this for CONTAINER_GROUP rather than CONTAINER_GROUP_INSTANCE?
Thanks!
With a bit of help, this worked for me in case anyone needs it 👍
type(CONTAINER_GROUP),toRelationships.isInstanceOf(type(CONTAINER_GROUP_INSTANCE),fromRelationships.isCgiOfNamespace(type(CLOUD_APPLICATION_NAMESPACE),entityName.startsWith(“<NAMESPACE NAME>”)))
