Summary:Dynatrace supports tagging Kubernetes entities for improved observability and automation. This thread explains how to apply tags at cluster, namespace, and pod levels using Dynatrace Operator and best practices for dynamic tagging.
I need to tag all entities (workloads, pods, & nodes) in a Kubernetes cluster via auto-tagging rules.
There is no way for me to do this with the rule type as “Monitored Entity” as a Kubernetes entity type (workloads, nodes, or anything K8 related) are not available to select. So, I assume the only way I can do this is by choosing the Entity Selector option when creating a tagging rule. But I need a way to tag 100+ workloads and 200+ pods without creating 300+ rules.
I was hoping I could tag all entities under a Management Zone, but Dynatrace doesn’t allow that, as specifying a Management Zone yields an error. I then thought I could do this at the cluster level, but adding a tag to the cluster doesn’t cause it to pass down <type(KUBERNETES_CLUSTER),entityName(“myK8ClusterName”)>. According to Dynatrace, entity types here are the seemingly relevant properties I need:
It looks like I need to string together these values in order to be able to tag what I need but I am running into issues getting it to work. I talked to Dynatrace support via chat and I was given an example of what worked for them before (but doesn’t work for me because it relies in a pre-existing tag).
From an automated dynamic tagging stand point it isn’t. But if you are willing to do a 1 to 1 it can be done via relations. For example. lets say I have a Namespace that resides under a cluster and I want to tag it with my own value. You can use the entity selector and leverage relationship tagging. via this string:
Apply ‘<EASYTRAVELCLUSTER>’ to Entities matching type(“Cloud_Application_Namespace”), toRelationships.isClusterOfNamespace(type(“KUBERNETES_CLUSTER”), entityName(“<CLUSTERNAME/ID>”))
Now it will apply that “Easytravel” as my custom tag value to the namespace if and when that namespace is related to the defined cluster via Dynatrace AI. You can then do this for the other aspects such as Pods.
It requires some thinking out of the box and isn’t truly scalable for large organizations as you have to define them one by one.
@shakib I also have created a RFE that is requesting the ability to leverage pod labels as tags and such. this would help reduce the usage of the entity selector. Dynatrace needs to expand the dynamic tagging capabilities to all the auto discovered properties. Feel free to give it a like
Thank you, Chad, that worked perfectly for the name spaces.
If I have 10 name spaces then it seems I’ll have to create 10 individual rules to cover each workload inside each individual namespace.
I was able to use the same logic for Workloads and the working syntax below shows all workloads being tagged for namespace XYZ which belongs to cluster ABC.
Hi @BaliBan if you mean through the UI there is no place where you can see the output, but for example if you add to a MZ or reference the Kubernetes Cluster the tags are there. If you use the API you can see the tag reference:
Hi @vinnu_arige_moe I leave you this link but have in mind this observation. As a result, Kubernetes processes monitored in your Dynatrace environment will have Kubernetes labels attached as Kubernetes tags. For namespaces, pods, and workloads, Kubernetes tags are not evaluated.
Everyone ok? Thank you very much for the topic, it helped me a lot here in my environment.
I was facing the same problem and I noticed that after entering the cluster through the Kubernetes menu, in settings (…) the option to create a management zone for the cluster is presented, within which there are the following rules:
- Dimensional rule for METRIC whre DIMESION k8s.cluster.name equals YOUR CLUSTER NAME
- Kubernetes namespace on Hosts where Kubernetes cluster name equals “CLUSTER NAME”
- Kubernetes services on Hosts where Kubernetes cluster name equals “CLUSTER NAME”
- Kubernetes workloads on Hosts where Kubernetes cluster name equals “CLUSTER NAME”
I was having trouble inserting the Nodes and pods into the Management zone and the first rule did that, I just needed to insert it into my existing mz
I got to know about below option in URL for tagging Kubernetes Pods, Where we can configure custom tags using “Environment API v2” ->Monitored entities - Custom tags ->POST method. All we need is Below mention EntitySelector and tag value
Do you also know a way to easily tag GCP integration (custom devices)? I’ve noticed that all gcp entities from integration are identified as custom devices.
All the information needed is under the entity types API in the Environment v2. The request is Gets a list of properties for all entity types. I leave you the link to docs but feel free to contact me for further details.
What is the right way to organize a management zone for a namespace where the user can view the infrastructure-related issue (CPU-limit quota saturation)?
Also, what are the rules to apply the tag on the following for a specific namespace?
Hi @Babar_Qayyum I’ve made for you the rules based on Namespace Entity ID as you requested because is the most restrictive approach, have in mind that for access you can only navigate via Kubernetes Workloads UI Menu (NOTE: Host information for the Kubernetes Cluster have been omitted because I understand that you only need from Namespace to below):
