Tagging for HTTP monitors running on specific synthetic location
We are looking to create a Maintenance window for the HTTP Monitors that are running in specific synthetic location. As per this post , i think its not possible in Dynatrace - https://community.dynatrace.com/t5/Synthetic-Monitoring/Maintenance-window-over-specific-location/m-p/218451
So we tried to create tags for the HTTP Monitors that are running in specific synthetic location using Automatic tagging approach. But we haven’t found any condition with respect to synthetic location.
Is there any other way on how to solve this use case ???
Maybe you can apply a naming convention with the locations and create an autotag from there.
Example synthetic name: MyWebPage [L_Dublin,L_Paris]
You can create a tag based on the following entity selector, and then choosing that new tag as a filter condition for your Maintenance Window:
type("HTTP_CHECK"),fromRelationships.runsOn(type("SYNTHETIC_LOCATION"),customizedName("YOUR_LOCATION_NAME"))
Osum. Many Thanks HannahM
