Tagging rights for users
Is it possible to assign rights to a user so they can manually add a tag without the “change monitor settings rights” on a management zone?
Found the solution by building a policy:
ALLOW settings:objects:write, settings:objects:read, settings:schemas:read WHERE settings:schemaId = “builtin:tags.manual-tagging”;
Hi @bhb_tenhave
Please find an example below for maintenance window settings.
For manual tagging create a new policy and bind it to the read only user group (which ones do not have configuration rights)
ALLOW settings:objects:read, settings:objects:write, settings:schemas:read WHERE settings:schemaId = “builtin:tags.manual-tagging”;
I hope it helps.
Best regards,
Mizső
hello ,
this works fine, but is it possible to grand only tagging permission to certain tag keys?
so users are only creating Tags within a range of keywords.
regards André
Dynatrace does not directly support restricting tagging permissions to specific tag keys.
@Mizső pointed in the right direction.
If you’re in SaaS, you can create a specific app that calls the API with only a few values.
