I am trying to configure the Cisco network device configuration through the Terraform script. I downloaded the Extension from Hub, and init, plan commands are successfully executed and after executing apply command, I am getting an error of No write access for scope class tenant. In API token I given the all the scopes, till it is giving the same error.
Please fine the Terraform code below:
resource “dynatrace_hub_extension_config” “test” { name = “com.dynatrace.extension.snmp-generic-cisco-device” value = jsonencode( { “description”: “Cisco device configuration”, “version”: “2.1.4”, “value”: { “enabled”: true, “description”: “test”, “snmp”: { “devices”: [ { “ip”: “0.0.0.0”, “port”: 161, “authentication”: { “type”: “SNMPv3”, “userName”: “user”, “securityLevel”: “AUTH_PRIV”, “authPassword”: “password”, “authProtocol”: “SHA”, “privPassword”: “password”, “privProtocol”: “AES256C” } } ] }, “featureSets”: [ “BGP”, “Health”, “High availability”, “Interfaces”, “Interfaces 32-bit”, “Interfaces 64-bit”, “Memory pools”, “Power supply”, “Sensors”, “Traffic” ] }, “scope”: “ag_group-default” } )}
Note: I am having full platform access.
terraform
Hello @Manoharsomi
The syntax for how to configure these settings via Terraform is not exactly the same as the JSON code presented in the WebUI suggests. What makes matters worse here is that the error message thrown back from the REST API leads you down the (wrong) rabbit hole of permissions.
You should be able to apply the monitoring configuration using this code:
resource "dynatrace_hub_extension_config" "test" {<br> name = "com.dynatrace.extension.snmp-generic-cisco-device"<br> active_gate_group = "default"<br> value = jsonencode(<br> {<br> "description" : "Cisco device configuration",<br> "version" : "2.1.4",<br> "enabled" : true,<br> "description" : "test",<br> "snmp" : {<br> "devices" : [<br> {<br> "ip" : "0.0.0.0",<br> "port" : 161,<br> "authentication" : {<br> "type" : "SNMPv3",<br> "userName" : "user",<br> "securityLevel" : "AUTH_PRIV",<br> "authPassword" : "password",<br> "authProtocol" : "SHA",<br> "privPassword" : "password",<br> "privProtocol" : "AES256C"<br> }<br> }<br> ]<br> },<br> "featureSets" : [<br> "BGP",<br> "Health",<br> "High availability",<br> "Interfaces",<br> "Interfaces 32-bit",<br> "Interfaces 64-bit",<br> "Memory pools",<br> "Power supply",<br> "Sensors",<br> "Traffic"<br> ]<br> }<br>)<br>}
Thank you so much @reinhard_pilz . provided solution is working perfectly
Hi @reinhard_pilz ,
Could you please provide the Terraform script to modify the host group name through API?
No idea about Terraform, I only use Monaco but, I think you can download an existing configuration to check how config files should be created.
Best regards
Hi @reinhard_pilz
Any update on Terraform script to modify the host group name through API?
your assistance is highly appreciated.
Thank you,
Manohar
