The websphere active "thread pool max" metric has a decimal point in customer chart
I have setting a websphere Active threads(Max) in customer chart.
But why does the active thread (Max) have a non-positive integer value? This is very strange to me. Has anyone encountered it before or can answer me why such a value appears?
ActiveCount is a BoundedRangeStatistic in PMI, so it may have a scale. A scale less than 1 can produce a fraction. Please check your PMI values in the Websphere performance viewer.
Best
Harry
I refer to this file and see that the static value of Active thread is “int”, so I think the value should be an integer.
Or does Dynatrace process the values again?
The value itself is int, but in PMI you can define a scale. If the scale is not an int, the result of activeCount will be decimal. Please check in the WAS admin console → performance viewer.
See
Best
Harry
