Threshold no longer available for Honeycomb Dashboard?
It looks like thresholds are no longer available for honeycomb dashboards. For other values ​​such as “single value” or “line” they are still available for example.
Honeycomb :
Line :
Can you give me the reason why it does not appear? it was available before, I had made thresholds for a honeycomb tile yesterday.
Thanks in advance
Hi @Etienne1 ,
Thresholds were never supported on the Honeycomb chart, however you can acheieve a similar / the same result with the custom coloring features that are located in the coloring sub-menu in the chart’s settings.
Thanks for the reply !
