Time difference between Dynatrace and machine
we’re noticing a time discrepancy between Dynatrace and the machine logs. Dynatrace appears to be one hour behind. This seems to be related to the recent time change in Egypt, as the machine time is correctly set to Riyad time zone. Could you please advise how we can ensure the timestamps match — specifically for Node.js technology — so there’s no time difference?
Hi, maybe you can try changing the timezone in your user settings It’s possible that the current setting doesn’t match your actual timezone. To do this, go to User Settings and select the timezone that matches yours.
