Timeseries Metric Data API not working
Hi Team,
I am trying to fetch metric data using following request
Request:
{“timeseriesId”:“com.dynatrace.builtin:servicemethod.errorcounthttp5xx”,“entities”:[“SERVICE_METHOD-9ACB771237BE05C6”],“startTimestamp”:1532770980000,“endTimestamp”:1532771100000}
But it fails with following error message:
Status Code: 400
Response Body: {“error”:{“code”:400,“message”:“The entity SERVICE_METHOD-9ACB771237BE05C6 is not allowed for the given timeseries id.”}}
Hi Pranjal,
Could you provide any screenshot just to see what parameter you are actually passing. I just tested in my environment it is working fine for me
Thanks for reporting that. This is a bug introduced in latest deployment. We will fix it within the next hours.
Sorry for the inconveniences.
Best regards,
Wolfgang
Wolfgang,
Is the bug fixed. As i still the issue with version 1.150.93.20180727-120510
Pranjal
Sorry for the delay, let me check with dev team.
The bug is fixed on all Saas Clusters. There we can fix it without a code change (by switching a feature flag)
In general version 1.150.105.20180807-100248 contains the fix for managed environments
Hi @wolfgang ,
Do you know if this fix was backported to older versions. I am having this issue with Managed version 148.96. Please advise.
NJ
