Timeseries with entity name
When I run the DQL timeseries cpu=avg(dt.host.cpu.usage), by:dt.entity.host, I only get the ID for each series. When I run the equivalent metric selector builtin:host.cpu.usage:splitBy("dt.entity.host") in the Data Explorer, the list is broken down by hostname.How can I display the hostname with DQL?
Hi Stefan, you just add the host.name to the dimensions you want to split by
timeseries cpu=avg(dt.host.cpu.usage), by:{dt.entity.host, host.name}
