TIPS - DQL Timeframe selection
I’m taking the liberty of sharing this tip because I’ve seen several people share difficulties in selecting a specific timeframe with the DQL, particularly when searching for information in the Logs.
Here are some examples to get around current limitations :
  • For -1d/d :
fetch logs,from:toTimestamp("T00:00:00")-1d
  • For -0d/d :
  • For GMT+2 :
fetch logs,from:toTimestamp("T00:00:00+2")
I hope this TIP can be useful to as many people as possible :slightly_smiling_face:
Please let me know your comments.
Great​:blush: Thank you it’s a very useful
Great !
What is this “toTimestamp” function?  I tried searching for it and, while I see it used in examples in their documentation, I don’t see any explanation of what the function actually is, and my Google searches aren’t producing results.
*EDIT* Ahh, found it.  It’s in their Conversion and Casting Functions section of their docs instead of in their Time functions section.  They should maybe cross-reference those though, just to make finding it easier.
Hi all ,
Thanks for the tip here 😀
Do you have any other tip if we want to go through relative timeframe?
like if I want relative timings (like “now-1h/h to now-0h/h”) or “from: now-1M/M to :now-0M/M” , I have the message “The parameter `from` has to be constant”
I have not found any tips to do so.
Temp solution I have found is to query larger data and then filter afterwards :
|filter getHour(timestamp) >= (getHour(now())-1) and getHour(timestamp) < getHour(now())
Is it possible to do it directly from timeframe filter ?
Best regards,
Christophe
Thanks for sharing useful tip.
Hi all,
additional tip , for those who wants to use dashboard timeframe in one calculation
For example, if you want to use the timeframe of one dashboard in one tile , here is a tip you can use :
| lookup [
data record(timestamp=now())
| makeTimeseries sum(1)
| fieldsAdd fk=1, timeframe=timeframe[end]-timeframe[start]-interval
], lookupField:fk, sourceField:fk, fields:{timeframe}
For example,  you want to have Outage duration  calculation from Davis Events
fetch events
| filter event.kind == "DAVIS_EVENT"
//you can add any filter here
| fieldsAdd duration=event.end-event.start| filter isNotNull(duration)
| fields event.start,event.end,duration,arrayLast(entity_tags),Tags=arrayFlatten(entity_tags)
| summarize `Outage Duration`= sum(duration), by:{ Tags}
| fieldsAdd fk=1
| lookup [
| fieldsadd `Availability : 100%-duration outage`= if(100*(1-(`Outage Duration`/timeframe))>0,(100*(1-(`Outage Duration`/timeframe))),else:100) , `Outage Duration`=if(isNull(`Outage Duration`),0,else:`Outage Duration`)
| fields Tags,`Availability : 100%-duration outage`,`Outage Duration`
Kudo to the support team to have found this while I got exotic request :slightly_smiling_face:
Christophe
Thanks, very helpful! A small additional hint when interested in UTC. Add the “Z” to your timestamp format. Example:
fetch events, from:toTimestamp("T00:00:00Z")-1d, to: toTimestamp("T00:00:00Z")
| summarize by: {}, sum=count()
gives use the count of events for yesterday, measured in UTC.
Edit: “T00:00:00Z” appears to be just a shortcut for “T00:00:00+0”
Cheers, PJ.
