TLS handshake error on PCF
We’re getting a TLS handshake error on our Cloud Foundry.
In the documentation I see that there’s this option:
“If you haven’t installed a trusted certificate to your ActiveGate, make sure to clear the Require valid certificates for communication with the API server (recommended) checkbox.”
However, it is unclear where I can find this checkbox. I was not able to locate it.
Hello @KVZ ,
You can find this checkbox when you select “Connect manually” in the Kubernetes section of the menu. Then, you’ll see the “Require valid certificates for communication with the API server (recommended)” checkbox right under the “ActiveGate Group” dropdown menu.
Hi @MaciejNeumann
What about for Cloud Foundry?
The Dynatrace CF docs mention the same as your answer: Connect your Cloud Foundry foundations with Dynatrace — Dynatrace Docs
But the configuration is a different UI and endpoint.
Settings → Cloud and Virtualization → Cloud foundry
And not through k8s at:
Kubernetes → Connect Manually
Any luck finding a solution? I have the same message and I am also configuring directly in the Cloud Foundry.
No luck in the current version, but I’m updating this ActiveGate integration to be a Dynatrace Extension and have included the option to disable SSL verification. This should be released to the Hub within about a month.
