One of the applications we monitor has transactions that involve multiple write/read operations to JMS queues. Currently the PurePaths do not provide end-to-end visibility to these transactions. I viewed a performance clinic video on the topic of distributed transaction tracing, and if I understood correctly it would be necessary to use the OneAgent SDK to provide support for the end-to-end visibility. Is that correct, or is there any other approach that we could take to enable the end-to-end visibility?
Yes, if you have a break in your PurePath because of not fully supported technologies you can utilize the OneAgent SDK to manually instrument the application and link the PurePath together.
There are ways to do that without modifying your code, like using AspectJ. Reach out to extensions@dynatrace.com and we can help you with that if you need some guidance!
