Transaction storage limit
Hi all.
How can I know what is the limit for transaction storage?
Is there a way to calculate this limit?
I am receiving this message very often, and I think it is because I have no limit:
thanks in advanced.
Jose A
Transaction storage keeps the most granular monitored data - mainly pure paths, but also details on Synthetic monitors or user’s visits.
You can control transaction storage size with many triggers:
- Service request level retention time
- Service code level retention time
- Number of monitored entities - transactions, hosts etc.
It’s hard to estimate how much storage is needed, as it depends on many aspects. If you see “data truncation alerts” I recommend adding more storage, or if not possible - lowering retention times.
Thank you @Radoslaw S. very much for reply.
To reduce retention periods, do you mean these 2 values?
best regards
Jose A
Correct. These 2 are major triggers that impact transaction storage size.
@Alfred-Le
