Transactions & services timeframe DT MANAGED
We are having a problem with the data we get in transactions & services in DT Managed.
If we set a timeframe in the format “Last X hours” we get different results than if we specify a time frame in the format “Today xx:yy - aa:bb”
Example : When we set “Last 6 hours” we get nothing
but when we specify Today 6:15 - 7:15 (Which is in the last 6 hours timeframe) we get some high CPU problems and stuff like that.
Do you have an idea about this problem ?
Thank you
Did you considered that on that list by default visible are current values not calculated over whole timeframe? You can change that behavior on top of entities list.
Yes I have considered that but how can i change that ?
When you have last XX minutes / hours / days this showing property looks like this. When you pick exact timeframe this is changed to calculated over whole timeframe. This is why you have different results.
Thank you so much.
That was very helpful
