Im using SNMP extension 2.0 and the metrics collected are stored in a entity.
I would like to visualise the information in the tab Technology overview, but for that I think I need to transform the entity generate in the extension to a custom device and custom device group.
I dont like the way to search entities in Dynatrace find-your-new-entities-un-ui , having to write the entityType in url to find the entities, for me its a bad way to navigate in the Dynatrace UI, and this way that im trying to implement would solve this problem.
As the way forward with external entities in Dynatrace is generic topology I don’t think you should try to “hack” it with the custom devices. Could you create a product idea for visualizing generic entities so your use case is captured?
Generic entities and generic topology could be used perfectly for that, including grouping hosts as well as linking hosts to generic entities. For more information you can see this part of the documentation: Define custom topology — Dynatrace Docs
If you have a need to visualize generic entities on the technologies page, please go to the product ideas section of the community forum.
I have already add the idea in the community forum. 😊
Im having some problems to understand all the possibilities using the documentation custom topology .
The devices I have to monitor in each room are very different in terms of monitoring implementation (OneAgent, plugins python in ActiveGate, Legacy Application that send a state to log files, SNMP extension 2.0). In the end I need to have a way to have all this information aggregated.
So, your recommendation is to forget passing the metrics from entities to custom devices. Instead, I send metrics from OneAgents and the other monitoring implementation to entities.
Do you have any example to extract metrics from a custom device or host to entity?
