“There are no records” message appears instead of chart in 2 cases:
- Where result set is empty / no records returned
- All timeseries to display contain only nulls / no values
To avoid this we need to make sure that there is always a result and it contains data. Null is valid value of timeseries which means no data, but it this it may be caused as a result of division of 0 by 0
Additionally there is another problem with join in this query: left query (timeseries with “failed == true” condition) will not return a timeseries for a specific service when there is no failed requests and this cause that a service will not be present in the final data at all.
Final query can look like this:
timeseries total = sum(dt.service.request.count, default:0), nonempty:true, by: { dt.entity.service }
, filter: { ( in(dt.entity.service, classicEntitySelector("type(service),tag(\"Kubernetes_ClusterName:payments\")"))) }
| fieldsAdd key=record(dt.entity.service)
| join [
timeseries failed = sum(dt.service.request.count, default:0), nonempty:true, by: { dt.entity.service }
, filter: { failed == true and ( in(dt.entity.service, classicEntitySelector("type(service),tag(\"Kubernetes_ClusterName:payments\")"))) }
], on: { key }, fields: { failed }, kind:leftOuter
| fieldsAdd failed = coalesce(failed, icollectArray(total[]*0) )
| fieldsAdd expression = failed[] / total[]
| summarize { expression = avg(expression[] ) }, by: { interval, timeframe }
| fieldsAdd expression = coalesce(expression[],0)
| sort arrayAvg(expression) desc
What are the components of it:
- Use of nonempty:true parameter ensures that there is always something returned by timeseries command. In case of query with by: record with null value of dimension will be provided.
- I included entity filter in timeseries command. Having it after would eliminate special record produced by use of nonempty:true parameter
- kind:leftOuter was used to ensure when there are no “failed” requests, “total” timeseries is not eliminated
- join command works this way, so record keyed by null will not be connected. To avoid this behavior we can wrap “dt.entity.service” in a record and use it in join condition
- In such case value of “failed” timeseries is null, so
makes sure we have array of zeroes instead
- To avoid nulls being result of 0/0 division, they can be replaced with 0s:
