Hi
I’ve been working with Dynatrace for a long time, and Multidimensional Analysis has always been one of the most powerful and straightforward tools in the platform. Getting the p99 response time for Database statements (split by {Request:Name}) used to take just a couple of clicks.
Now, with the push towards the new Distributed Tracing app, what used to be a routine daily task has become an incredibly frustrating experience. Beyond just losing the intuitive UI for custom percentiles, I am running into several critical issues:
1. Broken Migration Workflows When I use the UI prompt in Multidimensional Analysis to “Switch to the Distributed Tracing app”, it simply breaks the tracing. The context is lost, the feature doesn’t work as expected, and I have to start from scratch.
2. Unexpected Consumption Costs & Incomplete Data Because the UI no longer gives me the p99 aggregations easily, I am forced to query the spans directly. This approach has already generated consumption costs just trying to replicate a basic, previously free dashboard view. To make matters worse, despite the cost, the data returned feels incomplete compared to the old analysis.
3. Overall QA and Broken Links in New Tenants Honestly, it feels like there is a lack of testing behind these UX changes. I am finding multiple broken links across the new tenants, which gives the impression that the user journey isn’t being thoroughly tested before deployment.
Am I missing a straightforward, cost-effective workflow inside the new UI to get my custom percentiles back? Is anyone else struggling with these broken links and unexpected query billing?
The banner on top says: “Switch to the Distributed Tracing app - replacing Multidimensional analysis; or use Notebooks for advanced exploration”. But if basic, out-of-the-box analysis now requires writing paid DQL queries in Notebooks just to see a p99 on SQL queries, this feels less like an upgrade and more like a workflow downgrade with an added cost. and not even its the same result
I would love to hear how other teams are handling this, and hopefully, someone from Product Management can shed some light on these QA and usability issues.
