TreeMap | FontSize style for text
Hi!
Is there any way to increase the font size of the Canvas of treeMaps? Im creating a few Advance “Dashboard App” with Focus in banking. But the text of the treeMap is too small when showing it in any TV. The text just is so small… like text for ants.
Any way, couldn’t find anyway to increase the text size with the ootb props of the chart.
Is there any way to be able to do this?
Cheers!
Hey @Dant3 - no this currently isn’t possible.
Could you share a screenshot of an example to help illustrate your use case?
Sure,
Please note that this TV is located in the management office, and because it is viewed from a distance of 2 to 3 meters, the text on the treemap might appear faint. The graph illustrates the functions of the mobile banking app based on customer loyalty levels, with each node representing a specific functionality interaction.
If i Cant make the text bigger, then i would need to import another framework that allow me to do this.
Thanks! I’ll take it with me and see what we can do in a future iteration
