I created a custom service on specific process group and the service got detected but after some time I have seen 2 more custom services with the same name got detected on two different process group.
In my case the same class and method is being used by other 2 process groups but they are having different name. Why the scope is not limited to selected process group.
Hi Suresh,
When you edit the custom service after you create it, you should see a dropdown arrow for the option to “Optionally restrict custom service rules by process groups”.You can add the process group you want to filter this for. Please let me know if this works for you
NJ
Yeah I got it , It seems the issue got resolved after applying the changes.
Thanks NJ
