Troubleshooting Kubernetes logs in Log module
Summary
This article helps you troubleshoot Kubernetes-specific log collection issues with Log module. It covers no logs appearing, missing or incorrect Kubernetes metadata, and gaps in container logs. It applies to Log Module deployed via OneAgent (Classic or Cloud-Native Full-Stack) or Dynatrace Operator (Kubernetes Log Module), on both SaaS and Managed environments.
Problem
You see one of the following:
  • No logs at all from Kubernetes workloads, or no logs from a specific namespace or node.
  • Logs are visible in the Logs app, but lack Kubernetes metadata such as k8s.namespace.name, k8s.pod.name, k8s.workload.name, or k8s.workload.kind.
  • Logs are visible in the Logs app, but the Container detail view in the Kubernetes app shows No logs found.
  • Pod annotation–based ingest rules are ignored.
  • Time-series log volume charts show periodic gaps.
Kubernetes metadata attached to Container Output logs
For reference, this is the metadata that Log Module attaches automatically to logs ingested as Container Output:
Attribute Description Notes
k8s.container.name Container name
k8s.pod.name Pod name Numbers preserved
k8s.deployment.name Deployment base name Numbers generalized to *
k8s.pod.uid Pod UID
k8s.namespace.name Namespace
k8s.cluster.name Cluster display name
k8s.workload.name Exact workload name Requires .spec.logMonitoring and the Collect all container logs flag
k8s.workload.kind Workload kind Requires .spec.logMonitoring and the Collect all container logs flag
k8s.pod.annotation Requires .spec.logMonitoring and the Collect all container logs flag
k8s.pod.label Requires .spec.logMonitoring and the Collect all container logs flag
dt.entity.container_group_instance Container entity ID Full-Stack OneAgent only. Used by the Container screen in the Kubernetes app
Key rule: Logs ingested as Container Output (via the container runtime) automatically receive Kubernetes metadata. Logs ingested from file-system paths via a custom log source pointing to /var/log/pods/... don’t.
Troubleshooting steps
Before opening a ticket or investigating a specific scenario, verify all items in this checklist.
#CheckHow to verify
1A log ingest rule exists for the desired logsSettings > Collect and capture > Log Monitoring > Log storage configuration. Select the relevant scope at the top left.
2.spec.logMonitoring is present in the correct DynaKube
kubectl
 get dynakube -n dynatrace -o jsonpath='{range
.items[*]}{.metadata.name}{"\n\t.spec.logMonitoring:
"}{.spec.logMonitoring}{"\n\t.spec.metadataEnrichment:
"}{.spec.metadataEnrichment}{"\n"}{end}'
3.spec.metadataEnrichment.enabled: true in the DynaKubeSame command as above
4ActiveGate has the kubernetes-monitoring capability
kubectl
.items[*]}{.metadata.name}{"\n\t.spec.activeGate.capabilities:
"}{.spec.activeGate.capabilities}{"\n"}{end}'
5No conflicting ingest rules at a higher scope override your include ruleCheck hierarchy and overrides on the Kubernetes cluster scope
6No ingest.warning attribute on existing log recordsDQL: fetch logs | filter isNotNull(dt.ingest.warnings)
7Operator DaemonSet pods are running on every node
kubectl
 -n dynatrace get pods -o jsonpath='{range
.items[*]}{.metadata.ownerReferences[0].name}{"\t"}{.spec.nodeName}{"\n"}{end}'
 | grep -E 'logmonitoring|oneagent'
If the checklist passes, match your symptoms to a scenario below.
Resolution
No logs from Kubernetes
Log storage rule not matching
Symptoms
  • Container logs don’t appear in Dynatrace, even though the cluster is fully monitored.
  • No ingest warning is present on any record because no record exists.
Cause (brief)
Log ingestion is a two-step process: source detection (automatic) and log acquisition (requires an explicit ingest rule). A source definition alone is not sufficient. It must match a rule with Include in storage set.
Resolution
  1. Go to Settings > Collect and capture > Log Monitoring > Log storage configuration.
  2. Select the Kubernetes cluster scope.
  3. Add a rule with Include in storage that matches your target containers, namespaces, or workloads.
  4. Verify rule order: rules execute top-to-bottom; the first match wins. A broad exclusion above your inclusion silently blocks ingestion.
  5. Check the scope hierarchy: Host scope > Kubernetes cluster scope > Host group scope > Environment scope. A more specific scope takes precedence.
Tip: Add an explicit Exclude all rule at the bottom of the Kubernetes cluster scope to prevent fallthrough to a broad environment-level include rule.
Configuration changes propagate to agents within ~90 seconds.
PodListFuture not valid — missing .spec.logMonitoring
Symptoms
  • The OneAgent or Kubernetes Log Module pod logs repeatedly show:
<span>  [containersdetector] [error] Annotation retrieval failed: PodListFuture not valid (This message was ignored N times.)</span>
  • Logs from specific namespaces or workloads are absent.
  • k8s.workload.name, k8s.workload.kind, k8s.pod.label and k8s.pod.annotation are missing.
Cause (brief)
Log Module cannot reach the Kubelet API because the DynaKube is missing .spec.logMonitoring, which grants the required RBAC.
Resolution
Add .spec.logMonitoring and .spec.metadataEnrichment to the DynaKube that contains .spec.oneAgent:
yaml
spec:
  logMonitoring: {}
  metadataEnrichment:
    enabled: true
Apply the change:
bash
kubectl apply -f dynakube.yaml
If the error persists after a few minutes, restart the Log Monitoring DaemonSet:
bash
kubectl rollout restart daemonset -n dynatrace <log-monitoring-daemonset-name>
Note for Full-Stack deployments: .spec.logMonitoring does not deploy a separate Kubernetes Log Module DaemonSet when .spec.oneAgent is already defined. It only activates log monitoring inside the existing Full-Stack OneAgent and grants it the RBAC needed to access the local Kubelet API.
The PodListFuture not valid error does not prevent log collection — only metadata enrichment is affected. Records are still ingested, but without k8s.* attributes, they won’t appear in the Kubernetes app or workload-filtered views.
.spec.logMonitoring in the wrong DynaKube
Symptoms
  • After adding .spec.logMonitoring (and .spec.templates.logMonitoring), log collection does not improve.
  • The PodListFuture not valid error persists.
Cause (brief)
.spec.logMonitoring and .spec.templates.logMonitoring must be in the same DynaKube as .spec.oneAgent. If you have separate DynaKube objects for the ActiveGate and the OneAgent, placing the log monitoring configuration in the wrong one is silently ignored.
Resolution
Move .spec.logMonitoring and .spec.templates.logMonitoring to the DynaKube that also contains .spec.oneAgent.
Example of a correct split-DynaKube configuration:
yaml
# DynaKube 1: ActiveGate
spec:
  activeGate:
    capabilities:
      - kubernetes-monitoring
# DynaKube 2: OneAgent + Log Monitoring (BOTH must be here)
spec:
  oneAgent:
    applicationMonitoring: {}
  metadataEnrichment:
    enabled: true
  logMonitoring:
    ingestRuleMatchers:
      - attribute: k8s.namespace.name
        values:
          - production
          - staging
Init container permission failure on SELinux / OpenShift
Symptoms
  • The Log Monitoring DaemonSet fails to start.
  • The init container (bootstrapper) can’t access the required host paths and exits with a permission error.
  • The DaemonSet ends up in Init:Error or CrashLoopBackOff.
Cause
SELinux blocks the bootstrapper from accessing host paths required for Log Module setup. Most commonly seen on OpenShift, but applies to any environment with SELinux enforcement.
Resolution
Add the feature.dynatrace.com/oneagent-privileged: "true" annotation to the DynaKube manifest:
yaml
apiVersion: dynatrace.com/v1beta3
kind: DynaKube
metadata:
  namespace: dynatrace
  annotations:
spec:
Restart the DaemonSet:
bash
Logs visible but missing data or metadata
Specific namespaces not ingested
Symptoms
  • Some namespaces produce logs visible in Dynatrace; others do not, despite identical configuration.
Resolution
Work through the common causes in order:
Cause Fix
No ingest rule for those namespaces Add a k8s.namespace.name matcher to the ingest rule
OneAgent is not running on the nodes hosting affected pods Confirm the OneAgent DaemonSet has pods on every affected node
Custom log source conflict on /var/log/pods Remove the custom source — see Custom log source blocks Kubernetes enrichment
Higher-priority scope has an exclude override Check host, host-group, and environment scopes for conflicting rules
The dynatrace namespace is missing The dynatrace namespace is excluded by default. Enable Allow OneAgent to monitor Dynatrace logs under Settings → Collect and capture → Log Monitoring → Advanced log settings
Container screen shows “No logs found”
Symptoms
  • Logs are accessible at the workload, namespace, or pod level in the Kubernetes app.
  • The Container detail view shows “No logs found.”
Cause
Container-level log display requires the dt.entity.container_group_instance attribute. This attribute is only added by the Full-Stack OneAgent. It is not added by the Kubernetes Log module or by App-Only deployments.
Resolution
This is by design for App-Only and Kubernetes Log module deployments. Logs remain queryable via the Logs viewer using k8s.container.name, k8s.pod.name, etc.
If container-level display in the Kubernetes app is required, deploy Full-Stack OneAgent on the affected nodes.
Symptoms
  • Kubernetes metadata (pod name, namespace, deployment name) is missing from logs, even though the cluster is fully monitored.
  • Custom log source rules targeting /var/log/pods/ or /var/log/containers/ are present in the configuration.
Cause
A custom log source matching Kubernetes container log directories bypasses the automatic container log detection pipeline. Log Module treats those files as plain host-level logs and does not attach k8s.* metadata.
Resolution
Remove the custom log source rules that target /var/log/pods/ or /var/log/containers/, then use ingest rules with Kubernetes matchers (such as k8s.namespace.name, k8s.pod.annotation, k8s.workload.name) to control what gets ingested.
For step-by-step resolution, see Troubleshooting missing logs → Custom log source blocks Kubernetes enrichment.
Warning: After removing path-based custom log sources, logs may stop appearing entirely if no matching ingest rule exists. Ensure an ingest rule covers Container Output before removing the custom source.
k8s.deployment.name shows wildcards (*)
Symptoms
  • Filtering by k8s.deployment.name fails because numeric parts are replaced with * (for example, pricing-service-v24 becomes pricing-service-v*).
Cause
k8s.deployment.name is the base pod name with numeric suffixes generalized. This is by design, it groups all replica pods under a single entity, consistent with how Dynatrace entity modeling works.
Workarounds
Use k8s.pod.name (numeric suffixes are always preserved):
<span>fetch logs
</span><span>| filter startsWith(k8s.pod.name, "pricing-service-v24")</span>
Or upgrade to OneAgent ≥ 1.307 and Dynatrace Operator ≥ 1.4.1 and use k8s.workload.name, which contains the exact workload name without generalization:
<span>fetch logs
</span><span>| filter k8s.workload.name == "pricing-service-v24"</span>
Pod annotation–based rules ignored — Collect all container logs toggle
Symptoms
  • Pod annotation–based log ingestion rules are ignored. Logs from annotated pods are not ingested.
Cause
Whether the Collect all container logs toggle is required depends on the deployment type.
Deployment Toggle required? Min version
OneAgent DaemonSet (Classic / Cloud-Native Full-Stack) Yes OneAgent 1.309, Operator 1.4.2
Kubernetes Log Module (spec.logMonitoring only) No OneAgent 1.309, Operator 1.4.2
Resolution (OneAgent DaemonSet only)
Turn on Settings > Collect and capture > Log Monitoring > Log module feature flags > Collect all container logs at the Kubernetes cluster scope.
Log gaps and inconsistencies
Log Module at performance limits
Symptoms
  • Periodic gaps in log volume are visible as drops in time-series charts.
  • High-throughput pods show intermittently missing logs.
Cause
Log Module processes data in 60-second intervals with configurable throughput limits. When log volume exceeds the default limits, the agent falls behind, and gaps appear.
Resolution
Processing and upload limits are adjustable per environment and are handled individually by Support. Open a support ticket with:
  • The affected cluster and namespaces.
  • The approximate log volume from the affected pods.
  • A screenshot of the volume gap in the time-series chart.
What’s next
  • For boundary issues (multi-line entries split incorrectly, entries merged), see Troubleshooting log record boundary detection.
  • For broader “missing logs” troubleshooting beyond Kubernetes, see Troubleshooting missing logs.
  • For ingest delay (logs arrive but late), see Troubleshooting log ingest delay.
  • For JSON parsing issues (wrong timestamp from JSON field, severity mapping), see Troubleshooting JSON log parsing.
  • For log rotation issues (gaps at rotation boundaries, missing rotated files), see Troubleshooting log rotation issues with Log Module.
Related reading
