Troubleshooting "Your ActiveGate configuration is not supported."
Self Service Summary
If you see this message in the Deployment Status page of your ActiveGate, it means that you manually added an additional purpose to the ActiveGate, which is not supported.
An ActiveGate is designed to serve a single purpose at a time.
This is typically the result of manually modifying the custom.properties file and adding a module from a different scope.
To resolve this, please edit the custom.properties file, ensuring that the appropriate path is used for the operating system in question. Once this is complete, please restart the ActiveGate.
If you still face issues even after performing these steps, please raise a support ticket and include a detailed description of the steps you have taken to check the issue, as this will help us to investigate it more efficiently.
