Tunnel between Environment ActiveGate and Dynatrace Saas Cloud
Is it possible to set a tunnel(for example VPN) between Environment ActiveGate and Dynatrace SaaS Cloud? Or it is actually same as setting a proxy between Environment ActiveGate and Dynatrace SaaS Cloud? As far as I aware is proxy acts as a gateway where tunnel will establish a secure connection.
This is mainly due to the company’s policy where everything that goes to public must have a secure connection from their security team.
Thanks for the reply.
No, you can’t do that for SaaS. Dynatrace communication is already secured by TLS-1.2. Using a HTTP proxy does not matter, as it only forward the HTTPS traffic.
See more details in the docs:
