I have created a browser monitor and trying to add certificate but getting error.
Error: This type of credential is not supported here
Maybe credential type is not correct. Could you doble check type of credetial in the credential vault?
Best regards
Hi Anton,
I did not get you which type you are referring to, if it’s certificate then it’s .pfx
