Update Operative System in cluster nodes RHEL8.9 to RHEL9.4
Hello community, I have a managed cluster with 3 nodes running RHEL8.9, I removed a node to update the operating system to RHEL9.3, when I want to do the process of adding a node to the cluster it starts to show errors, my question is What is the best route to update the OS?
Hello @smascorro Assuming you have spare hardware or virtual machine, I recommend that you add a 4th cluster node with RHEL version 9.4 and remove the next one to upgrade, always make sure you have at least 3 nodes at all times, this is not required but is recommended to avoid synchronization problems.
I don’t have a fourth machine due to resource issues, what I’m trying to do is seize a node, I updated the operating system from a new installation and what I’m trying to do is integrate it into the cluster already with the updated system, but I am having problems
this is the image
install the nft with firewalld
also, check the other clusters installation directories and make sure to use the same standard. and try to create the nodekeeper manually
