For the second time the planned automatic update of 1.224 has been suspended.
The Automatic update window in the Cluster Management Console shows the next warning:
Upgrade has been suspended by Dynatrace Mission Control. Operation will not be started during maintenance window until we make sure it works reliable at your environment. There is no further action required from your end.
And Version 1.244.161.20220712-184054 has been downloaded, but cannot be installed at the moment.
Contacting support about the nature of the suspension and if there is an underlying issue in the platform on our end, they told me that an issue in the package downloaded has been noticed (Cluster Version 1.244), so we have paused the upgrades for this version until the developers can fix it. That’s why you are seeing that message. Once it is fixed, the Cluster will be upgraded with the proper version and build.
This applies to all Managed environments. They are already working on it and it will be released as soon as possible.
Due to the fact that I (as contact) did not receive a notification of the suspended update (and eagerly was going to check an improvement in the new version, which I didn’t find), I entered a Product idea for it, here:
Inform Managed contacts about planned upgrade issues - Dynatrace Community
